TR6 Blower
davjac889
Hello All,
Any thoughts as to why every time
I pull the blower on it blows a fuse?
I mean every time, it doesn't even get
a chance to run.
Thanks
poolboy
A wire or spade connector on the switch maybe contacting metal and when you try to complete the circuit..there she blows.
TRopic6
Definitely check the switch as PB says. Also could be stuck. A non-turning motor like that is close to a dead short. Of three TR6s I've had that had been off the road for many years, two had stuck fan motors. I had to pull the heater;remove the glove box and pass-side heater ducting, and you can struggle it out the passenger side with moderate contortions and cussing.
Jeff
74.5 & 75 TR6
RAC68 Cold Air Bilge Blower update Austin Healey 13
R BJ7 heater blower vibration Austin Healey 11
wangdango BJ8 heater blower? Austin Healey 4
AHS BJ8 blower motor switch - how to replace? Austin Healey 1
D Another use for a leaf blower. Restoration & Tools 1
Joe Schlosser Bugeye combo Heater blower Switch Spridgets 4
D TR6 Blower motor Triumph 1
steveg Heater Blower voltage drop Austin Healey 8
N Replacing Heater Blower Austin Healey 7
bugedd Heater blower wanted...oops Spridgets 8
D TR6 Blower runs off and on Triumph 4
D TR6 Blower fuse Triumph 4
D TR6 Blower working! Triumph 3
L Fresh air and Blower intake hose replacement on BJ8 Austin Healey 12
maxwedge5281 heater blower ducting Austin Healey 6
D TR6 76 TR6 Heater/Blower Switch Triumph 1
R Heater Blower Motor Austin Healey 9
M About to install blower [pic] Triumph 9
R Blower assembly question Spridgets 1
P POLISHING HEATER BLOWER HOUSING Spridgets 7
I Shop to check heater blower motor in Washington? Triumph 6
I TR6 TR6 heater blower wires -what are these wires for? Triumph 8
S Heater Blower Installation Austin Healey 5
billspohn Oddball Defroster Blower Other British Cars 7
jvandyke heater blower wiring Spridgets 2
roofman Spitfire Spitfire blower fan won't turn off Triumph 5
F TR6 TR-6 Blower Bearing Noise Triumph 3
I bugeye heater blower attachmetn help Spridgets 9
bcbennett TR6 TR6 Blower switch Triumph 6
trrdster2000 Fix that blower switch Triumph 3
John Moore Midget with Blower FS Spridgets 1
Woodie heater blower, demister/defroster Spridgets 8
AUSMHLY Fresh air hose clamp, heater blower ground Austin Healey 5
ObiRichKanobi Shot Blower motor??? Triumph 1
zimmy TRADE?-heater blower Spridgets 3
MadRiver TR5/TR250 Silly TR250 Vent/Blower Question Triumph 1
Brosky Heater blower blowing fuses Triumph 6
T Blower Motor for 7 Triumph 1
T MGB 1980 MGB heater blower motor MG 1
T MGB Heater blower motor for 1980 MGB MG 2
B Blower Motor Always On Austin Healey 2
P TR6 72 tr6 heater blower Triumph 2
7 Sprite Blower Spridgets 8
T Blower Motor Triumph 0
M AC/Heater Blower Problem Jaguar 2
S Wedge TR7: Wiper & blower won't work! Triumph 6
