TR4/4A Block Water Outlet Valve
KVH
I have two TRs. Both water outlet valves in the block were leaking from the "faucet," not from the block where the fitting goes in. I ordered one new once from the usual outlet, and it's now leaking, too. My other one was already fairly new. I cleaned it and reinstalled it--but it's leaking still. So I have both cars leaking fluid.
What's the deal? The antifreeze I'm using? Defective manufacture?
Should I just run some "stop leak" and forget about it.
After sending defective parts back over the past few months I'm beginning to imagine the difficulty the distributors must be having with reliable suppliers. You would have been surprised to see my steering tube bushings a while back. The internal nylon inserts were so loose they just fell out.
Anyway, advice on stop leak for the valves please? Too cheap a fix?
CJD
Yes...the new valves are defective. They are machined, but not ground. This leaves circular machining marks on the metal parts that prevents them from sealing.
A work around until better valves are available is to take the valve apart and lap the cone into the housing. Then reassemble using a thick grease or plumber's sealant. I trie lapping unitl the machine marks were removed, but then the cone becomes too small for the housing...so only lap until the cone and housing mate completely around, but not until the machine marks are gone.
ghawk16
I hate stop leak. Especially after I had to replace my engine in my V8 4Runner because someone used it and caused a plug somewhere in the coolant lines causing my small radiator tube to pop off at highway speed which then drained all the coolant, overheated the engine and blew it out in the middle of Nevada on the Extraterrestrial Highway.
groupdeville
If you want to keep the valve for looks:
Remove it from the block and drill/tap the inlet (threaded) end of the valve assembly for a brass machine screw, Allen-head screw, or 1/8" pipe plug. Thread the screw or pipe plug in (with sealant), and replace the valve assembly into the block (with a copper washer, and perhaps a little sealant on the washer as well). The valve will look completely stock, but you'll have to remember to unscrew the whole valve assembly when you want to drain out the block. But how often do any of us actually do that - maybe once per year?
Dr_Mike
It looks as though I shall take off my "new" valve and replace the old one which I still have lying about. I won't be any messier to operate than a leaky new one. But hard to get at with the car on the ground.
Sarastro
After messing with the one on my MG TD, I finally just cut it off and plugged it with a screw. You can easily drain the block other ways, and it's just not worth the trouble. I could also remove the screw for drainage, if I wanted.
RJS
Huh, I installed a new one this past summer using thread sealant. No issues.
Bob
KVH
KVH
It's not leaking there. It's leaking right out of the spout. I called the distributor. They've had two defect recalls over the past 7 years, one in 2016 when I ordered mine.
RJS
I see, what a PITA. That's exactly why I prefer to rebuild the original part where I can. The OEM quality is almost always is better than this "new" aftermarket stuff. I would have reused mine but the valve was frozen and the little handle sheared right off when I applied too much torque trying to open it. No choice but to replace it.
Bob
sp53
What I did (learned from Don E) take your valve out-- fillthe end with sealant-- let that dry, and put it back in for originality. When youwant to drain the system remove the whole unit.
I seriously try and avoid stop leak also. If you need it, then something is wrong and you have to think through the problem seriously. I fix a low pressure block leak once, and I was glad to use it, but on a radiator deal or heater deal, I 99% fix the problem.
I have friend that toasted a nice BMW with it, and he could not even find a shop that wanted to fix it, and he has the money. One shop finally did put a junkyard motor in for 6K.
jimstr4
Yes my both my old and new block water outlet taps leak.
I think that I'll block the end with hotwater compatible sealant and put it back for originality sake.
KVH
KVH
Can I just fill mine with ultra black gasket sealant, let it dry and put it back in? I'd think so.
Graham H
I changed the tap for a modern ball type valve which I can fit a 1/4 inch hose on the end to direct the coolant away from the block and chassis. Because it's tucked away under the manifold you have to be looking for it to see it's not the original type valve.
Graham
KVH
KVH
The "sealant" was a waste of 24 hours. Like some above suggested, coolant just leaked out the bottom spring fitting. In other words, the problem wasn't just the seal at the ball valve. My fix was to just plug it with a pipe threaded plug the same size. If I own the car another 20 years I probably won't pull that plug more than twice. No big deal, but very nice to not be leaking on the floor each night. I now own three new, defective valves.
J Engine block modification for oil to water jacket leak Austin Healey 8
T TR2/3/3A thread pitch for TR3 water tap in block Triumph 4
KVH TR4/4A TR4 Water Drain Plug in Block Triumph 4
mountainman TR2/3/3A TR3 Block Water Tap Triumph 11
MTribe How to clean engine block and head water deposits? Triumph 12
sim A-series Engine Block Search Spridgets 2
B TR6 71 block & crank Triumph 1
T Block Heaters Austin Healey 3
tinman58 TR2/3/3A Por-15 in engine block? Triumph 12
R For Sale 100 engine block w/head Austin Healey Classifieds 3
Sopwith_Camel what is this on the block? Jaguar 13
BoyRacer Mystery 3000 Engine Block Austin Healey 2
jfarris TR2/3/3A Plug/cap sizes to block off heater Triumph 5
healeynut For Sale 100/4 block and head Austin Healey Classifieds 1
tj_tr3_tr6 Wanted Wanted / Need / TR4 Engine Block for 62 Tim from So California Triumph Classifieds 3
Chuck9482912 Letters Cast Inside Engine Block Austin Healey 0
A Land Rover V8 3.9L long block core for sale Rover / Land Rover 1
P TR2/3/3A Block treatment post cleaning Triumph 17
Bayless Ready for final block sanding Spridgets 5
Joel Lester TR2/3/3A "TR3" painted on the engine block Triumph 13
R Rust in Block? Help needed! Austin Healey 6
D TR6 Disconnecting pipe from engine block to oil pressure gauge Triumph 6
HealeyRick For Sale Bare 29F Block, Cylinder Head and Manifold Austin Healey Classifieds 2
T For Sale Triumph TR6 N.O.S engine block [late] Triumph Classifieds 2
nichola TR6 Classic Technologies front sealing block Triumph 7
nichola TR6 Aluminum block engine Triumph 8
M 948 Cylinder Block Studs - Sequence on Cylinder Block Spridgets 4
CinneaghTR TR4/4A Hole at Bottom of Threaded Stud Hole in Block Triumph 6
F TR2/3/3A SU 1 3/4 Carb to Manifold Insulating Block; '59 TR3A Triumph 6
Bremer TR2/3/3A Block deck height? Triumph 10
Bayless Memory block Spridgets 3
D TR2/3/3A Coolant tap on TR3 block Triumph 3
Got_All_4 TR6 Should I paint the inside of the block? Triumph 17
T Oil filter block plate - really? Austin Healey 13
6 1275 Head to block dowel pins Spridgets 10
D New Fuse Block Configuration Austin Healey 21
Sarastro TR4/4A Engine block deck flatness Triumph 9
D 3000 engine block Austin Healey 0
H Machined Engine Block - Cleaning before assembly and paint. Not sure what to do? Spridgets 5
S BJ7 frozen temperature sensor to block Austin Healey 17
D mystery of the day... pedal block? Austin Healey 5
D TR2/3/3A Block coolant passages plugged - pull the head? Triumph 46
simon1966 Numbers stamped into a BN1 block? Austin Healey 5
M TR6 Front sealing block Triumph 11
H Post-War Other Herald rear suspension lower block installation Triumph 3
D Engine Block Austin Healey 14
jfarris TR2/3/3A Head stuck on block Triumph 8
