bobmga62
Okay..
continued reference to my soft clutch
I have replaced the Clutch slave, the flex pipe and the complete master cylinder, when I took the master cylinder out I could see that the push rod was damp on the exterior (of the clutch) so I assume that is the culprit.. weeping of the fluid within the cylinder
but..
now I cannot get the system to bleed properly... though I had thought I had bench bleed the system correctly, by putting the cylinder on a vise and pumping fluid through it..
the front brakes are grabbing, the rear brakes don't even accentuate,, and when I open the bleeder, they just drip a bit, even with pressure.
and when I do the clutch, and I open under pressure, I get no fluid..
sounds like I got one heck of an air pocket in the master..
Is there a way I can eliminate the bubble without taking it all apart again..
thanks
r
but..
thanks
r
