fairmounter
I am hoping my problem is air in my clutch line. Had my slave cylinder and rubber hose replaced recently because the pedal was not effecting the clutch as much as normal (like a leak, and it was gradual). Slave cylinder was assumed to be the problem since it was old and the master is pretty new. Now the clutch does not work at all. I was hoping that it is still air in the line. The shop is sure it needs a new clutch. I bled the line myself by the old have someone pump while you open the valve method. Fluid came out several times, I never noticed air bubbles coming out, just fluid. I am still hoping it is air since I realize it is a very difficult to spot to bleed. Should I get one of those devices that forces the fluid up through the bleeder to the mc? or does the lack of any air bubbles when I bled it make it unlikely that there is still air in there.
Strange thing, when it is running in neutral, it bogs down when I push the clutch in and I can only put it in gear with the engine off.
Please tell me it is definitely air (or the master).
, but sorry to add an unnecessary thread none the less.
