BJ8 window glass installation??
Dave, I will soon be doing the windows as my package arrived yesterday from VB with the new glass. My package from Moss should arrive today with the new seals and as soon as I get some time I will do one. I'll post an update after I get one done.
Ed
edk, how are your rubber seals around your vent windows? now would be the time to replace them if needed,dont want to take all this apart again, just a sug. /ubbthreads/images/graemlins/savewave.gif
Right you are Anthony. I have two new vent window gaskets on my workbench. My dad bought them years ago and I planned on using them as they still appear to be in good shape.
/ubbthreads/images/graemlins/thumbsup.gif
I finished installing one of the new glass panels into the metal frame. I drilled out the original rivets to disassemble. I noticed that the side of the original glass was missing most of the glazing, the bottom still had most of the original glazing intact. I had to clean up some rusted areas on the metal pieces and then primed and painted them. I used 1/8" medium steel pop rivets to reassemble the frame. I also installed new plastic spacers. Now to the hard part, getting the glass seated into the metal pieces using the glazing strips. A small piece of paper came with the glazing strips, " use petrol rub to vulcanize the glazing strip " so I rubbed both sides of the glazing strips with vasoline and then went to the store. When I came back I tried assembling the glass into the metal pieces using the strips. No go. The strips were too thick but I could tell that they had softened up a little from the vasoline. I sprayed them down with 3 in 1 penetrating oil. That did the trick, I was then able to attach the bottom metal piece using the softened glazing strip. I have some rubber backed carpet squares covering my workbench. I also put down an old piece of carpet and then placed the glass panel upside down on my work bench. I was then able to hammer the metal piece down onto the glass, using a small plastic headed hammer. The side piece did not want to cooperate. The glazing strip was sheared off from the force of me trying to hammer the metal piece onto the front side of the glass. Probably due to the curve. The upper half of the glazing strip, furthest away from the corner is where the strip was ruined. I tried another piece, same thing. I remember what Anthony said about inner tubes and noticed that I had saved one of the old rubber bands from the inside of my wire wheels. I cut a piece of this rubber to match the damaged portion of the glazing material. I removed the damaged glazing material and installed a piece of rubber which I had sprayed down with penetrating oil. On the 1st try, the side metal piece seated down onto the glass. It was a very good, snug fit and felt right as I was hammering it on. Based on my experience, it would appear that using a piece of inner tube or wire wheel rubber spoke protector is the best material to use for the assembly process. I guess it isn't as " sticky " as the glazing material, but since it doesn't get as deformed when you install it, it probably does a better job filling the space between the glass and the metal pieces. On the other window, I will use the glazing strip that I already have on the bottom but use a piece of rubber on the side. Thanks to Anthony's tip to use a piece of rubber, and John's tip to use oil to soften the glazing strips, I got the job done.
/ubbthreads/images/graemlins/thumbsup.gif /ubbthreads/images/graemlins/thumbsup.gif
edk, well done old bean, well done! when you get to changing the vent window seals check out my post on " vent window seal replacement" theres a picture on how the bottom stem/piviting pin comes apart,it looks as if its a one piece machined unit when in fact it comes apart, im glad to see i was of some help after all thats what this forum is about, sharing our experiences, succeses, and the agony of "da-feet" /ubbthreads/images/graemlins/jester.gif /ubbthreads/images/graemlins/savewave.gif
ED,
Thanks for the post. I will find time in the next few weeks to work on this.
Inspiration is good at this point, I'm looking forward to posting a pic of my finished '64 BJ8 in the next few months.
DAT
I am also hoping to get my 65 finished in the next few months and I will also post some pictures when I " get R done "....More /ubbthreads/images/graemlins/hammer.gif then much /ubbthreads/images/graemlins/driving.gif
I just did my windows and vent windows two weeks ago. The 20 year old vent window seals I used have little waves in them. Do new ones also have those waves?
Hangtown,
I have new moss seals but they were bought many years ago. I don't see any waves in them. Just a lot of white mold release powder on the surface of the rubber.
