I just need to get expert clarification. The vacuum advance for a BJ8 (64 PH II) is to be disconnected and plugged when setting the maximum advance of around 35 degrees at >3000RPM and 15 degrees at 600-700 RPM at idle, tickover or whatever it is called.
YES??
Thanks,
So follow up question with vacuum advance connected and working properly what advance should one see at idle and at >3000RPM??
YES??
Thanks,
