AUSMHLY
I'm in need of some front and rear bearing shims for the BJ8 transmission.
Moss, AHS, DW don't sell them.
Does anyone know the specific sizes of these and where I might be able to buy them?
Moss lists two sizes for the front, .002 and .004. No size mentioned for the rear. I don't think front/rear are interchangeable.
I believe their purpose is to insure there is the correct amount of contact/pressure between the Mainshaft bearing and the Overdrive Adaptor Plate and the 1st input shaft bearing and the Clutch Housing. So the Mainshaft/1st input shaft is pressed firmly together limiting free play?
What happens if the shims aren't sized correctly? Will the gears on the 1st motion/Mainshaft and or Laygear have excessive wear? Not shift smoothly? Make noise?
