AUSMHLY
64BJ8, timing is off.
I had the distributor and vacuum professionally rebuilt, incase that question comes up.
Running Pertonics.
Last tune-up, I set the timing to 800, TDC 15 degrees with a Snap-on digital timing light. Car runs great.
It's been six months, car doesn't idle well anymore, noticed the tach shows 600 instead of the 800 I set it to.
Checked the timing, it's now at TDC 10 degrees.
Checked the distributor, it's tight. Had to loosen the distributor bolt to get it to rotate.
Moved it till I got TDC 15 degrees, car runs great again.
What's going on?
Running Pertonics.
What's going on?
