BJ8 Seat Thickness
M
Micahde
I am 6', 230lbs and I have the hardest time getting my legs on opposite sides of the steering wheel. I think my newly stuffed seats are too thick. Does anyone know the proper thickness of the seats on a 65 BJ8?
Blue964
I don't think it's a peculiarity of BJ8s, all the later seats are similar. I had the same problem with my BT7 tri-carb I bought a few years back.
I'm only 5'8'' but have a proportionally long body and just found myself too high with my head protruding above the screen-top, not good!
I had purchased the car from Bill Rawles and he simply suggested that his trim guy take some of the stuffing OUT of the seats. Still looks good and I now sit IN the car and not on it!! Worth a try.
I think it was Norman Nock that recommended boring some holes in the seat bottom foams (he had a certain pattern). I've found that the seat foam compresses over time; I've replaced my BJ8's foams a couple times over 140K miles.
roscoe
If you take a 2.5 to 3 " hole saw to the seat bottom foam, which you can do without removing the upholstry and do not cut all the way through, you can pull out several cylinder shaped pieces. For me, the result was a softer and somewhat lower seat. I did it because the seat was simply too firm but sitting an inch or two lower was fine with me even though I'm only about 5'7" ( and getting shorter).
M
Micahde
will do. Thank you.
yes, the wind screen is at my nose.
bob hughes
I took 38mm off my foam and then a touch more before I was comfortable. I did not bore holes in my foam, I think that.it makes it too squashy. I left the passenger seat with full foam and it does not notice that much, if atall.
Cheers
B BJ8 Seat Sliders Austin Healey 4
Mickey Richaud Wanted Wanted: BJ8 Seat Track Sets (Both Sides) Austin Healey Classifieds 5
crispy BJ8 Rear Seat Back Upholstery Hardware Austin Healey 7
J BJ8 Rear Seat Changes, 1964 to Later Austin Healey 9
WHT Late BJ8 Seat Belt Mounting Points Austin Healey 8
S BJ8 Rear Seat Side Panels Austin Healey 3
wangdango BJ8 seat restoraton? Austin Healey 1
S Wanted Rear Seat Slide Bolts, BJ8 Austin Healey Classifieds 0
Marvin Gruber Bj8 seat track assembly Austin Healey 12
wangdango BJ8 front seat redo? Austin Healey 8
D Seat belts on a BJ8 -64 Phase 2 Austin Healey 20
tahoe healey BJ8 seat cover Austin Healey 4
L BJ8 Phaze III Jump seat back questions Austin Healey 2
C BJ8 Rear Seat Back Carpeting? Austin Healey 3
L BJ8 back seat attachment [new to big healeys but well versed in Bugeye] Austin Healey 2
Lotuswins BJ8 3 pt retractable Seat Belts Austin Healey 10
Lotuswins Seat Back on BJ8 Austin Healey 16
N BJ8 Seat Rails Finish Austin Healey 2
6 Correct BJ8 seat height? Austin Healey 7
J More seat room in a BJ8, tilt back?? Austin Healey 6
J seat belt intallation in late BJ8 Austin Healey 24
lreyburn BJ8 Seat Cushions Austin Healey 5
MadRiver BJ8 Seat Adjustment? Austin Healey 2
R BJ8 rusty seat pan Austin Healey 5
J Need BJ8 gas tank and seat attachment bolts. Austin Healey 5
C BJ8 Seat back angle Austin Healey 14
J Seat rail lever for PH I BJ8 Austin Healey 4
A BJ8 Rear Seat slide bolts Austin Healey 1
F BJ8 Exhaust Hanger Pictures Wanted Austin Healey 9
Patrick67BJ8 Custom BJ8 Dash Switch Panel Austin Healey 7
1 BJ8 History Trace Austin Healey 7
D BJ8 Top Installation Detail Austin Healey 3
S Wanted WTB: 3.5 ratio diff/pumkin for '67 BJ8 Healey 3000 Austin Healey Classifieds 0
AUSMHLY BJ8 Trans Cover Carpet Austin Healey 7
AUSMHLY BJ8 Carpet and Snaps Austin Healey 2
Overdrive45 BJ8 Interior Trim Austin Healey 8
nitro BJ8 Production Year Austin Healey 6
BoyRacer For Sale BJ8 disk wheel hubs, spindles & calipers Austin Healey Classifieds 0
S SOLD!! For Sale 1964 AH 3000 MkIII BJ8 Phase 1 Austin Healey Classifieds 2
Patrick67BJ8 BJ8 Factory Hardtop Rear Window Austin Healey 6
AUSMHLY BJ8 Clutch Pressure Plate, Old vs New Austin Healey 4
AUSMHLY BJ8 Clutch Fork Bush Replacement Austin Healey 5
