AUSMHLY
Does the top material get glued to the trim rail?
I'm assuming the 38 clips are attached to the curve of the trim rail, correct?
Then the rail gets pressed down on the rubber seal, which is sandwiched between the water channel, which gets screwed in place.
Does anyone have a photo showing the clips on the trim rail?
Thank you guys,
Roger
Thank you guys,
Roger
it was not glued except at those little flaps you mentioned that attach it to top of the frame top bows.---Keoke
