BJ8 Rear Seat Back Carpeting?
Chris_Masucci
Hi folks,
I've searched high and low, and through the concours guidlines and came up empty. I'm repairing the rear seat back folding assembly and recovering it on my BJ8. The original had a black carpet on the sections that are hidden when folded up, but visible when the seat back is folded down in "parcel shelf" position.
Is that carpet supposed to be the same color as the rest of the carpet in the car, or always black?
Also, do you know of any place to get that piece or is it a standard part of the carpet kits?
Thanks,
Chris
Patrick67BJ8
Hi folks,
Thanks,
Chris
If your carpet set is black including the interior the sqab carpet is black too. It was included in the last two carpet kits I purchased.
C
Chris_Masucci
Ok thanks. My carpet will be blue when I order it...which apparently needs to be sooner rather than later. May I ask who you bought your kits from? None of the usual suspects online catalogs show the squab carpet as part of the set.
Patrick67BJ8
The last carpet set I bought was from Sports & Classics in the late '70's. I would call the carpet suppliers and ask them if it's included even though it's not shown. I believe there's a vinyl strip in the middle of the fold of the squab carpet so it's a piece that has to be fabricated.
crispy BJ8 Rear Seat Back Upholstery Hardware Austin Healey 7
J BJ8 Rear Seat Changes, 1964 to Later Austin Healey 9
S BJ8 Rear Seat Side Panels Austin Healey 3
S Wanted Rear Seat Slide Bolts, BJ8 Austin Healey Classifieds 0
A BJ8 Rear Seat slide bolts Austin Healey 1
Patrick67BJ8 BJ8 Factory Hardtop Rear Window Austin Healey 6
AUSMHLY BJ8 Transmission Front/Rear Bearing Shim Austin Healey 2
John Turney BN4 to Early BJ8 Rear Axle Austin Healey 12
AUSMHLY BJ8 Rear Wheel Cylinder leaking Austin Healey 30
AUSMHLY Squeak from rear of BJ8 Austin Healey 51
C For Sale 67 BJ8 rear trunk luggage rack- Austin Healey Classifieds 0
G rear wheel studs on my 1967 BJ8 Austin Healey 5
AUSMHLY BJ8 rear axle oil seal Austin Healey 6
RickPA BJ8 rear wheel cylinder install Austin Healey 1
B BJ7 & BJ8 Interior Rear Quarter Panels Austin Healey 12
Dave Richards BJ8 Rear Brake Kit British Parts Northwest Austin Healey 4
J BJ8 rear main seal kit - is it necessary and worth the risk to install? Austin Healey 33
J BJ8 early P2 rear spring mystery - what do I have. Austin Healey 6
B BJ8 Rear Brake Questions/Advice Austin Healey 4
J Rear axle noises==BJ8 Austin Healey 7
B Rear view mirror location for BJ8 Austin Healey 14
Jeepster BJ8 rear leaf springs Austin Healey 2
L BJ8 Rear Interior panel fitting Austin Healey 7
L 1966 BJ8 rear trim panels Austin Healey 8
J Rear Axel/Bearing & Axle Seal.\ BJ8 . Austin Healey 5
P BJ8 phase 2 rear leaf springs Austin Healey 2
pkmh Removing Rear Hub on BJ8 Austin Healey 48
M looking for rear end gears for bj8 Austin Healey 25
A BJ8 Rear Drum removal Austin Healey 8
Jeepster BJ8 rear seats Austin Healey 12
AUSMHLY BJ8 Rear Trim Rail Austin Healey 34
S BJ8 rear brake drums Austin Healey 8
B BJ7 & BJ8 soft top rear seal Austin Healey 2
L BJ8 dome nuts on rear interior panel Austin Healey 5
6 Need help with BJ8 rear shock position Austin Healey 2
6 BJ8 Rear Shock Installation Austin Healey 1
Johnny Help Identify BJ8 rear mufflers Austin Healey 14
B AH BJ8 REAR SPRING INSTALLATION Austin Healey 5
B 3000 [not BJ8] Rear Springs - too stiff - why? Austin Healey 6
S BJ8 Rear Seats Austin Healey 7
J BJ8 rear boot floor replacement. Austin Healey 9
S Rear springs - BJ8 Austin Healey 1
AUSMHLY BJ8 rear wheel well gap size Austin Healey 17
A Tinkling rear brakes [BJ8] Austin Healey 5
H Rear springs BJ8 Austin Healey 7
F BJ8 Exhaust Hanger Pictures Wanted Austin Healey 9
Patrick67BJ8 Custom BJ8 Dash Switch Panel Austin Healey 7
