B
BobHorvath
Correct me if I am wrong but I believe that the purpose of the spring and plunger is one of by-pass. Isn't it true that the plunger is seated @ low oil pressure situations and as the pressure increases the plunger comes off its seat and allows the excess pressure to bleed-off or by-pass to protect the oil system including the oil pump (mouth-full). So if the seat/plunger is poor enough the pressure may not build especially @ low RPM. If the spring is weak then the pressure will prematurely find a relief path and thus not allow a pressure build up. So if you have a bad seat you have big problems. If you replace the plunger (inexpensive fix) you might improve the seal and maybe improve the pressure. If the spring is weak, replace it too as it is cheep. NET NET replace the plunger and spring. As for shimming the spring I have no personal experience but I do respect some who state that such a fix worked for them. I would not shim a new spring however as you would be changing the oil pressure control characteristics and covering up a much bigger problem elsewhere in the oiling system. If your oil pump is weak or your bearings are worn or your rockers are worn then your new plunger never comes off the seat and your oil pressure is low due to leaking clearences. The next easiest thing to do is to look @ the rockers and re-build if necessary. Or perhaps just do it as it too is cheap and easy. If you have done these three things and still don't like your oil pressure then you have three more choices; Rod bearings, Main bearings or the pump itself. Do it all or in sequence and you will eventually see the pressure you are looking for. When you are into the crank mic. it to be sure a new set of bearings will still seal. Keep going until you are satisfied @ the increase. When I get inside my pan I will do it all so I don’t have to open her up again. You may get by doing nothing as some have suggested but @ great risk. These fixes are nothing compared to broken internals and metal spread through out your engine. Peace to all!!
Hi Guest!
