BJ8 Hot Starting Problem
Scot
Guys, I'm having a hot start problem with my BJ8. It seems she wants to start cold soaked with a fully charged battery, but after it gets up to operating temp and is shut down for a few minutes it can't turn over. Obviously have gas and spark, but wondering if this could be an electrical problem like a coil or condenser or the related wiring. Everything looks tidy when I checked for these things. Anyone ever have a problem like this?
If the starter makes a groan as if trying to turn but never gets going, tap it with knock-off hammer, sometimes just pushing clutch in and out will do the trick, seems to be a magic window of under bonnet temp where this happens. Sometimes cleaning where ground strap attaches to fitting for terminal, or any other ground contact spot will do the trick, for a while. oh, cleaning every contact in trunk cut-off switch or when main lead connects starter, or even lead involved with solenoid, Jay, '65 3000
Guys, I'm having a hot start problem with my BJ8. It seems she wants to start cold soaked with a fully charged battery but after it gets up to operating temp and is shut down for a few minutes it cant turn over. Obviously have gas and spark but wondering if this could be an electrical problem like a coil or condenser or the related wiring. Everything looks tidy when I checked for these things. Anyone ever have a problem like this?
I think we need a clarification. Are you saying it won't start or that the starter motor can't turn the engine over? Two very different problems.
Assuming that it does turn over, try checking the wire from the coil to the side of the dizzy, or even just substituting it with a temporary. If you have sparks, this may not cure the problem, but it could be intermittent sparking as this wire has a tendency to break near a connection and then it is hit and miss. Once the engine gets cold, does it then start up again?
:cheers:
Keith the starter motor runs fine but the engine wont turn over when hot. Bob once the engine is cold soaked again it starts right up. I replaced this wire once with hardware store materials years ago so perhaps ordering it from a vendor and replacing might fix the problem?
Remove the wire between the solenoid and the starter and solder the crimped connections directly to the copper core . You may have a high resistance joint that when the engine heat heats up the cable the starter doesnt have the balls to turn the motor over due to high resistance .
Failing that put a gear reduction starter on it and solve all your problems .
Scot
That wire is part of the harness set up so can not be bought as a separate, Just pull the connections and wire in a new length between coil and dizzy, I travelled for years with just this quick fix before I rewired the car, so that should not be the cause of your problems - unless the wire is broken - usually near the connections.
:cheers:
Hi Scot, I was wondering how you made out with your hot starting problem. If your still having the same problem , I might have a suggestion .
Regards, Bobby R
Hi Bobby, I still have the same issue but have been trying to work thru the excellent suggestions on this thread. I would welcome your input.
Hi Scot, give a little run down on what problems you are having now and what have you tried to correct this .
Actually still having the same problem as originally posted...tried replacing wire between the coil and dizzy.
Hi Scot,
I kinda lost track of this thread. Let me see if I have it straight. When then engine is hot, the the starter motor can turn the engine but the engine won't start. You've replaced the coil, but it doesn't help. It sounds like vapor lock or the fuel boiling in the carb bowls to me.
Keith
Yes when the engine is hot the starter will turn the engine but it wont turn over and start. I did not replace the coil yet as it is pretty new but I may try that. I have a glass in line fuel filter connected as the fuel enters the carbs. It never really had this problem before but if the fuel is boiling or vapor lock how can I correct it? I have had the heat shield out once and replaced the material on it.
Once the engine is off, all the heat just builds up under there. I don't know of any way to cure the problem short of opening the hood and allowing the heat to escape. Mine is always hard to start after it's been running hard and then shut down, but it doesn't sound quite as bad as yours. The car doesn't quit or run poorly if you sit at a stop light for a while does it? If so, adding a 5-bladed fan will help move more air through the engine compartment and keep temperatures down. Doesn't help if you turn off the engine, though.
First check your point gap and then ignition timing, set your timing light to 15 degree advance and line up your timing marks at about 700 to 800 rpm. Also could be faulty tune up parts as well as we are getting so much junk from the major distributors these days! Bad points, condensers, rotors and caps. Do these simple things first.. A engine out of time can really heat up a very quickly and result in very hard starting.
Hi All, Just an update on my hard starting problem when engine hot...I have replaced ignition wire between dizzy and coil, replaced coil itself, replaced fuel filter, cleaned grounds and have checked point gap and timing. Problem persists. Any other suggestions welcome! Thanks...
