Moss part # 147 or 470-655, the slider support assembly is the piece that sits under the hood latch support bracket. The slider s.a. has two nuts welded to the bottom. Anyway, there is a circular hole in the center of the slider support assembly where the striker pin fits. On the bottom side of that hole there is a tab on one side of the hole that extends about 1/4 of an inch. Question, should that tab be on the drivers or passenger's side on a LHD car? Yes, I even took pics when I disassembled the latch, but the tab being on the bottom side doesn't show in the pic.
