Hello All:
With a dash refininshing project underway, I noticed some green copper looking corrosion around the control valve for the heater, which has leaked onto the top of the Heater Box. The box appears to be in good shape and not leaking from within at all, but I was wondering if the box top is black like the rest off box itself, mine has a layer of light corrosion and dust so I can't really tell?
I have the replacement temp control valve, and was wondering if anyone has had success replacing the valve with the heater still mounted? Any other tricks or cautions taking this unit apart? I understand that there is an adapter and an O-ring that have to go in the right order. /ubbthreads/images/graemlins/canpatriot.GIF
- Andrew1-
- Andrew 1-
Is it better to take the time, remove all the hardwear, mounts and hoses from the box. It
- Andrew1-
- Andrew 1-
Hi Guest!
