BJ8 Half-Shaft Oil Seal
BruceAllcorn
I've had an oil seal go bad on one of the half-shafts on my BJ8. Anyone know of a place to buy a bearing nut socket (2-3/16ths?) or a tried and true method to remove the bearing nut?
i was able to remove mine with a large set of channel lock pliers. you can get a good grip on the nut and the handles will fit between the lugs.
if you go the socket route, i believe it is a 8 sided nut. i got a 12 point one from amazon, i think, that worked well to tighten it back up. i could get it to 75 ft/lbs before it slipped off. but that was it. i can tell you that is much tighter than it was though.
the driver side wheel is a left handed thread.
Thanks for the info. I have ordered the tool from AH spares and also ordered the wrench that Moss carrys. I had previously ordered a bearing as I figured since I was going to all the trouble I might as well replace the bearing as well.
I am not familar with the face of the socket that AH Spares sells but some socket ends are radiused and can slip off the thin bearing nut.
A trick is to surface grind the end of the socket perfectly flat so that it has full contact with the nut.
There is a lot of torque going on here
