BJ8 Grille removal and Moss headlight relay installation
Hi again all. I finally found the receipt for the addition of headlight relays for AH. I ordered all I needed from Parts Express at www.parts-express.com. Here's the part #; one 330-078 12vdc dual relay socket, four 330-079 12vdc waterproof 5-pin relays with metal brkt.
This kit comes pre-wired and you'll have to cut the following wires to separate the Low beam relay from the high beam relay; LB to HB contact 87 yellow, LB to HB contact 86 white. With the mounting pre-wired it's easier to just splice the wires from the AH switch to headlights and move them to the relays. I don't have the parts cost but it is minimal.
Consult the shop manual electrical drawings for wiring, and Good Luck!
