My BJ8 has been running well until this morning. I came out of the garage using reverse, no problem. I set off on a long run only to find no overdrive but being in traffic left it until later when going to fill up with gas. I found i needed to reverse, oops, no reverse gear. The gearlever moves much further to the left than it should so misses reverse. After playing around at the pump I found out I could get reverse by going less than the full distance to the left with the lever till I found the way into the reverse gate so I have all four forward plus reverse available but no OD. I checked to the output of the OD relay, voltage is going to the 3/4 gear switch on the box but that seems to not be working. I had to continue running because I had 400 miles to do today which is now done but I have the same distance to do tomorrow. I assume the selector mechanism has come loose in some way and whatever should operate the OD 3/4 switch isn't operating it. Can anyone tell me what it is likely to be that has come ou t of alignment on theshifter. All forward gears are where they should be, reverse is available but not against the stop and there is no OD cos the solenoid doesn't get voltag. 2nd question, can I bypass the 3/4 switch so long as I am sure never to leave it in OD when I try to get reverse, How easy is it to get to the 3/4 switch wires/
Any help welcome.
Thanks
Ian, in the Rhone Valley, France.
Any help welcome.
Thanks
