Frank C.
My fuel gauge was repeatedly sticking on full and I had to tap it to get it loose, so I (maybe mistakenly) took it apart to see if I could fix it. In the process I loosened two nuts on the back of the gauge which I found out moves the magnetic poles for the gauge.
Now I don't know how to calibrate them properly. If I knew the resistance of the sending unit I could mock it up on the bench and get things working again.
Any other suggestions?
Thanks as always.
Frank
Thanks as always.
Frank
