BJ8 fuel consumption
DavidThorn
I have set the ignition timing on my late BJ8 to 35 max advance at 4000 revs (with vacum tube disconnected) . I have a timing light on which the advance can be set so it should be pretty accurate. But the fuel consumption has now dropped from a regular 24 mpg (UK) to around 20 mpg. Anyone any ideas?
I am confident the carbs are set up correctly all plugs are a nice grey colour. The dwell angle is 35 - not changed.
Before adjustment the car must have been running with the ignition well advanced. The distributor was about 15 degrees further clockwise than it is now.
By the way the car is running fine,a lot less `lumpy` than it was before. Its just the reduction in mpg that concerns me?
Ed Kaler
<div class="ubbcode-block"><div class="ubbcode-header">Quote:]I am confident the carbs are set up correctly all plugs are a nice grey colour. [/QUOTE]
Carbs a bit on the RICH side, David.
Plugd "shoulb be" tanish.
/bcforum/images/%%GRAEMLIN_URL%%/cheers.gif
Ed
I set the timing at 22 to 25 due to the 6500 feet I usually drive in but this weekend I went down to 100 feet and had to adjust bact to 15 becouse I got a surge at the greater advance. Smooth right out with the retarding all the way back home. Go figure. And as Ed says gray is too rich. I would think you would lack power with 35 degrees advanced.
Michael Oritt
More horsepower=higher fuel consumption.
Keoke
Watch out TH! David is stating the Maximum advance of the Dizzy at 4000 RPM which is the specified sum of the Mechanical and Vacuum advance at that RPM on the BJ8 engine.---Keoke-?
Well TH, I "Figure" them carbs got enough air down there to last them for ah week or two!---- /bcforum/images/%%GRAEMLIN_URL%%/laugh.gif
Ah, thanks, Keoke. 35 did seem too high at 600 to 800 rpm. I've got to try that high rpm timing some time. I think my car likes blue air better than brown anyway.
Cutrog1 BJ8 Fuel Tube Installation Austin Healey 10
S BJ8 Fuel Pump Austin Healey 13
B Fuel pipe runs BJ8 Austin Healey 2
Lutz Kramer Fuel gauge and sender unit for BJ8 Austin Healey 2
Bob_Spidell BJ8 Fuel Pump Trivia Austin Healey 0
M BJ8 Fuel pump Austin Healey 13
J BJ8 PhI ; #25805; Fuel Pump Austin Healey 20
T BJ8 Tachometer and Fuel gauge stopped working. Austin Healey 27
S BJ8 Fuel Gauge -Shows 1/4 tank when empty Austin Healey 10
pkmh BJ8 Fuel Tank Sending Unit - Ground Wire Austin Healey 8
Ed_K Correct SU Fuel pump for a BJ8 [ PSI specs] ? Austin Healey 9
AUSMHLY Float bowl fuel height BJ8 Austin Healey 4
G BJ8 Fuel Gauge Core Austin Healey 9
N BJ8 out of fuel at 1/4 full tank Austin Healey 4
Frank C. BJ8 Fuel Gauge Austin Healey 5
F BJ8 Fuel Filter Installation Austin Healey 14
L BJ8 FUEL TANK SPOTTED Austin Healey 2
G BJ8 Fuel gauge help Austin Healey 8
BOBBYR BJ8 FUEL TANK Austin Healey 7
J I need a picture of installed fuel pump for BJ8. Austin Healey 4
F BJ8 Exhaust Hanger Pictures Wanted Austin Healey 9
Patrick67BJ8 Custom BJ8 Dash Switch Panel Austin Healey 7
1 BJ8 History Trace Austin Healey 7
D BJ8 Top Installation Detail Austin Healey 3
S Wanted WTB: 3.5 ratio diff/pumkin for '67 BJ8 Healey 3000 Austin Healey Classifieds 0
AUSMHLY BJ8 Trans Cover Carpet Austin Healey 7
AUSMHLY BJ8 Carpet and Snaps Austin Healey 2
Overdrive45 BJ8 Interior Trim Austin Healey 8
nitro BJ8 Production Year Austin Healey 6
B BJ8 Seat Sliders Austin Healey 4
BoyRacer For Sale BJ8 disk wheel hubs, spindles & calipers Austin Healey Classifieds 0
S SOLD!! For Sale 1964 AH 3000 MkIII BJ8 Phase 1 Austin Healey Classifieds 2
Patrick67BJ8 BJ8 Factory Hardtop Rear Window Austin Healey 6
AUSMHLY BJ8 Clutch Pressure Plate, Old vs New Austin Healey 4
AUSMHLY BJ8 Clutch Fork Bush Replacement Austin Healey 5
AUSMHLY BJ8 Cylinder Head Installation Austin Healey 6
LAW75 BJ8 Brake Lines Austin Healey 2
AUSMHLY BJ8 Clutch Pressure Plate Brand Preferences Austin Healey 3
BoyRacer For Sale BJ8 spindles & disc wheel hubs Austin Healey Classifieds 0
G Wanted BJ8 Tonneau Cover Austin Healey Classifieds 0
Cutrog1 For Sale Healey 3000 BJ8.... a restoration saga Austin Healey Classifieds 0
AUSMHLY BJ8 Overdrive Oil Passages Austin Healey 2
