Hi Guest!
I have the same problem as you, but maybe worse! My new Jule frame came with new floorboards, outriggers and trunk floor but no holes were drilled, etc.I have just purchased an exhaust mounting kit from one of the parts suppliers and it came in 3 separate sections. Front,mid and rear.
I have looked at the diagram from Moss but I am struggling to see that much detail of what goes where. I can't believe there is so much to it.
The previous owner fitted an exhaust from an earlier car and non of the correct fixing points are remaining. I was hoping the new exhaust and fixing kit when assembled under the car would give an indication of what needed to be fixed or welded where on the chassis.
Does anyone have a photo to show the fixings when installed?
Patrick,
are you suggesting that the chassis frame should have holes drilled in it that some parts of the mounting kit bolt to?
I wasn't sure if the fixings were bolted on or welded on?
I am able to go look at an unmolested '67 Healey and last year I did that taking photos of the undersides as well as the top looking down(floorboards). I would post photos of what I have but I don't have measurements to go with them. (sometines I can post to the BCF no problem and then there are times it is impossible!). BCS sells some hardware that can be used to replace the broken studs that stick through the floor but I also figured that "elevator bolts, 1/4 x 20, would do the job too. The photos that AUSMHLY posted are a big help if you don't know exactly how the mounts go but won't help much if you need to know exactly where the holes go if you no longer have them such in as replacing the floorboards. If you temporay assemble the system as AUSMHLY says to do and raise it you have a chance in getting it righ or very close to right. I think the most critical point on doing it that way is to have the outrigger mount on your car in good useable shape.Patrick,
Here you go.Hi. I am trying to fit a new moss exhaust system to a bj8. I think the trunk floor has been replaced and so it is not clear how the resonator mount fits. Does anyone have any info on how the brackets are supposed to be? The system that came off was a straight run to the rear.
Many thanks!
John
