BJ8 door glass replacement
tomnanney
I have to replace the glass in the passenger side door, but I'm not sure how to secure it in the channel. Can anyone give me the proper way to do it?
Thanks
Tom
Healey Nut
It just fits in the groove with a rubber glazing strip ...its tight in there . If you dont have a new glazing strip then bicycle inner tube is a good substitute .
Patrick67BJ8
Thanks
Tom
Mine were glued in. They won't slip out that way.
vette
I just finished prefitting mine in my BJ7 to make sure everything is right before I paint the car this winter. I ordered the channel felts and plastic or nylon little runner buttoms from Moss. On the top of the channel that is part of the main assembly for the quarter window, there is a rubber stop fastened with a small screw. With the stop removed the windo will just slide up the channel and come all the way off at the top AFTER YOU HAVE REMOVED/RELEASED THE "CATCHING GUIDE" on the bottom of the lower horizontal window frame. That guide is the attaching point for the window regulator arm. It can be removed from the lower window frame by prising it off with a screw driver or you can tap it gently with a small hammer and a small drift. This guide just kind of clips or grips unto the lower window frame. A tip before you remove it, mark its horizontal position on the frame or window glass with a marker or scribe marks on the frame. When you go to reinstall the window and then to tap this guide back on, you don't want the guide to end up in a different horizontal position along the bottom frame. This could happen do to the radial position of the regulator arm depending on if you turned the handle. If the guide is not in the same position, its slider could pop out when raising or lowering the window. So mark it, it will be easier. Dave.
bob hughes
I did mine a few years ago and I used a clear silicone instead of the rubber in the channel - works a treat
The proper way of course is to use the rubber, but I could not get it to work properly.
:cheers:
Patrick67BJ8 Glazing Door Window Glass in BJ8 Austin Healey 15
Editor_Reid BJ8 Door Glass Austin Healey 6
LAW75 BJ8 Door Locks Austin Healey 2
B BJ8 door hinges Austin Healey 7
B Wanted BJ8 door hinges Austin Healey Classifieds 2
M 3000 BJ8 Door Seals Austin Healey 9
AUSMHLY BJ7-BJ8 outer weather strip for door window Austin Healey 4
wangdango BJ8 door hinge milling? Austin Healey 2
H Door seals BJ8 Austin Healey 15
Healey Nut BJ8 door Chrome waist strip Austin Healey 14
B BJ8 Door hinges Austin Healey 16
J BJ8 Inside Top Door Rails-How Attach? Austin Healey 6
C BJ8 door strikers keep slippng Austin Healey 7
J Where To Find BJ8 Key Door Lock ,Trunk & Glove Box Numbers ??? Austin Healey 3
B BJ8 door seal attachement point. Austin Healey 4
wangdango BJ8 door hinge pillar plate redo Austin Healey 7
Jeepster BJ8 - Glove box door lock Austin Healey 3
D BJ8 Door Seal Orientation Austin Healey 6
M Bj8 door disassembly Austin Healey 5
bighealeysource DOOR ADJUSTMENT ON BJ8 Austin Healey 12
crya Tricks for attaching door pulls on BJ8?? Austin Healey 8
S BJ8 Glove Box Door Retaining Bolt Austin Healey 5
J BJ8 door latches Austin Healey 3
J BJ8- How is the chrome door top molding installed? Austin Healey 11
bighealeysource door alignment on a BJ8 Austin Healey 1
C BJ8 Door latch question Austin Healey 9
J Replacing door hing pin on 64 BJ8 ph I Austin Healey 2
A Accurate - Door Pillar Finishing Welt Piping BJ8 Austin Healey 10
P Removing BJ8 Door Panels Austin Healey 21
S BJ8 Door Moulding Installation Austin Healey 6
6 BJ8 Door Latch Austin Healey 3
tahoe healey BJ8 door trim Austin Healey 3
F BJ8 Exhaust Hanger Pictures Wanted Austin Healey 9
Patrick67BJ8 Custom BJ8 Dash Switch Panel Austin Healey 7
1 BJ8 History Trace Austin Healey 7
D BJ8 Top Installation Detail Austin Healey 3
S Wanted WTB: 3.5 ratio diff/pumkin for '67 BJ8 Healey 3000 Austin Healey Classifieds 0
AUSMHLY BJ8 Trans Cover Carpet Austin Healey 7
AUSMHLY BJ8 Carpet and Snaps Austin Healey 2
Overdrive45 BJ8 Interior Trim Austin Healey 8
nitro BJ8 Production Year Austin Healey 6
B BJ8 Seat Sliders Austin Healey 4
BoyRacer For Sale BJ8 disk wheel hubs, spindles & calipers Austin Healey Classifieds 0
