Larry,
I'm sorry that you had a problem. It does happen occasionally. Quoted below is my note in this topic about cam break in.
https://www.britishcarforum.com/cgi-bin/ultimatebb.cgi?ubb=get_topic&f=5&t=000037
"The contact pressure between cam & lifters is very high. Especially before the high spots on cam & lifters are bedded in. You need to lube the cam & lifters with a lube that can withstand very high contact pressures. Molybdenum disulfide (moly) is the lube of choice. Many of the "better" cam manufacturers/grinders supply a tube of moly with instructions to USE it. & how to break in the cam.
The second item is cam break in. No prolonged low speed cranking/idling for the first 20 to 30 minutes. On the first start, rev the engine to 2000 rpm or so & keep it there for the 20 minutes. This gives the much needed extra splash lubrication to the cam & lifters during the first critical minutes of cam life. Most cams are ruined by improper lube/break in in the first few minutes of running.
Needless to say, the static timing, fuel mixture, oil & coolant leaks must be dealt with before the first start.
Some folks may disagree, & depending on the cam & lifter metallurgy may get away with lesser measures, but why take a chance."
Also mentioned in the thread is that the faces of the lifters should be checked for a minimum hardness of RC 50. Maybe your cam & lifter supplier can advise you further.
I can't advise on the best way to remove the cam.
