Two truly impressive gun shot size backfires and then would not start.
After a lot of tail chasing I find a freeze plug sized hole in the rear of the intake manifold log. Naturally it could not be at the front so I can simply hammer in a new one!
My local parts house only has a rubber style plug and I wonder if this will hold up?
Carbs done by Joe Curio 5000 km ago. Never backfired before.
Distributor done at the same time by Advance Distributors and I fitted a Pertronix, matching coil, cap, and rotor, yesterday as part of the tail chasing
Timing is correct, valves seem to be operating properly, 180 psi in each cylinder, fuel at the jet needles, spark at the plugs, plug gap .025.
Is this a known issue?
