BJ8 Air Cleaners - correct finish?
Ok thanks we will try to recoat tomorrow with much heavier spray. But with this particular spray can it starts to spit and leaves spots, so today I did back off a little and did not spray directly over the pieces, shot them horizontal so the spits (drips) fell before got to the piece. Maybe I just have a bad can. I have run across bad spray cans before where the nozzle is not spraying the way it should.
Thanks
jjs64bj8
jjs,
take your spray nozzle off and soak it in some mineral spirits (paint thinner) . I always do this after a few uses on my spray cans, the nozzles will clog and spit due to partially hardened/settled paint after use inside the small tube of the nozzle. Blow out with some compressed air and you should be good to go
