I was unable to get the bottom seal from Moss to fit. The one from Healey Surgeons fit fine. My problem is when I install on the car the seal pops out when I try to get the seal to spread out toward wipers.
Be sure the seal is clean and the windshield frame “slot” is clean!
I used a drop of Super Glue Gel to hold mine. A drop of glue about every inch only on the affected area is all that’s needed.
You can also use the Gel glue to hold the door seal weather stripping in the areas it will not hold too.
