BJ7 hood frame dimensions
bob hughes
Hi guys
I am working to a set of dimension obtained from this site several months ago to position the hoops for the hood. Does anyone know if the dimensions are taken along the centre line of the car or along the webbing lines.?
The dims are taken <span style="text-decoration: underline">beween</span> bows
front to first is 20.25 inches that is fixed and is the same whatever the line.
1st to 2nd 10 inches
2nd to rear bow 7.5 inches
and rear bow to body line is 14.5 inches.
I have problems with getting the 14.5 unless the line is on the webbing.
I have further problems with the side glass and hood frame relationship that can not be overcome by rotating the side windows - I need to close up a 6mm gap in the height and open up the gap at the rear by around 4-5mm.
Short of altering the fixing brackets on the body for the frame I can not figure out a solution. Some of the problem may be down to a slight sag in the chassis, shown up by the shut lines at the rear of the doors.
:cheers:
D BJ7 Hood frame mounting plate Austin Healey 7
B Best screws for woodwork to BJ7/8 hood frame Austin Healey 5
R New Hood for BJ7 Austin Healey 3
G Fixings for liner assembly hood comparment -BJ7 Austin Healey 7
chicken Hood Bow BJ7 and hood fit Austin Healey 6
chicken help with hood mounts bj7 Austin Healey 0
maxwedge5281 bj7 hood latch pull Austin Healey 6
B BJ7 hood installed Austin Healey 6
John Loftus Early BJ7 Hood [top] request Austin Healey 5
5 WTB: BJ7 Squab Austin Healey 13
5 BJ7 Boot Rust-Through Austin Healey 13
B For Sale Too many Healeys - BN2, BN4, BT6, BJ7 For Sale Austin Healey Classifieds 0
Walter74 BJ7 Throttle Linkage "Support Panel" Austin Healey 5
T BJ7 Trim Recession (Convertible Top) Austin Healey 2
ModifiedBJ7 BJ7 Windshield Surround Rubber Seal Austin Healey 2
chicken BJ7 Chrome Trim Austin Healey 15
JMACENGINESHOP BJ7 Engine Rebuilding Austin Healey 23
R BJ7 Rear Axle Maintenance Austin Healey 5
B Wanted Grill Top Cowl and Surround - BJ7 Austin Healey Classifieds 1
R Changing BJ7 Differential Ratio Austin Healey 10
X Trouble shooting trafficator - 1963 BJ7 Jaguar 9
T BJ7 Hard to find First Gear when G/Box is hot Austin Healey 3
B BJ7 Rear View Mirror Mounting Hardware Austin Healey 7
chicken BJ7 Door Fit Austin Healey 27
T Wanted BJ7 parts needed Austin Healey Classifieds 0
T Weight of BJ7 Transmission/Overdrive Austin Healey 10
D BJ7 Clutch Austin Healey 6
R BJ7 Back Seat-Rest Austin Healey 1
HealeyRick BJ7/8 Convertible Top Issues Austin Healey 5
HealeyRick BJ7 Side Window Alignment Austin Healey 31
B BJ7 Interior Finishing Details Austin Healey 2
chicken Healey BJ7 door (i think) Austin Healey Classifieds 0
chicken BJ7 Rear Number Plate Mounting Austin Healey 3
chicken BJ7 Door Seal Austin Healey 5
chicken BJ7 Rear Quarter Panels Austin Healey 6
B BJ7 Boot Trim Austin Healey 7
T Early BJ7 Vent Window Seal Austin Healey 2
D BJ7 Underdash Trim Austin Healey 9
G Steering Arm Installation Recommendations - BJ7 Austin Healey 2
D BJ7 Rear rail trim Austin Healey 0
D Wanted BJ7/8 front grill top cowl Austin Healey Classifieds 4
BLong63AH BJ7 Hard Fuel Lines Austin Healey 20
T Spin-On Oil Filter Removal [BJ7] Austin Healey 12
T Installing Garmin GPS in a BJ7 Austin Healey 19
pbraun How much does a BJ7 or 8 transmission weigh? Austin Healey 3
P BJ7 Upholstery Austin Healey 1
B BJ7 back end rebuild Austin Healey 1
Marvin Gruber BJ7 door panels Austin Healey 4
Marvin Gruber BJ7 Top Installation Austin Healey 1
