BJ7 heater blower vibration
RestoreThemAll
My heater blower does seem to cause some vibration. The one thing different about mine is that I changed out the motor for an AC Delco which runs nicely. Does anyone notice a vibration with the engine off and the blower on? I can feel in on the fender. I can see the squirrel cage and it seems to run true. Spinning too fast maybe?
Dl
steveg
The blower unit is mounted with rubber grommets as vibration isolators. If they're shot, that could be the problem. (Note use of 1/4-20 u-nuts on feet for ease of removal/replacement of unit.)
R
RestoreThemAll
I'll take a close look at the mounts tonight. Thanks Steve.
Healey Nut
The blower wheel may have lost its balance weight clip . Look for a clean spot on one of the blades where it was . If it had one it would be a small piece of spring steel similar to the fender screw clips but much smaller .
R
RestoreThemAll
Steve, the mounts are in good shape. couple years old.
Dale
R
RestoreThemAll
Healey Nut, how are things in the north? I think we have some of your weather this week.
No balance weights at all.
Dale
RAC68
Hi Dale,
I also changed the motor of in my heater blower, quite a while ago, with one out of an wrecked late 1960s Oldsmobile Starfire Convertible. With the original motor, I could breath heavier then the air coming through the defroster vent. Since the Olds installation, my defrosters move so much air that they whistle, even with the heater vents open.
When you changed the motor, did you install the squirrel cage on its shaft? If so, how? Depending on how you positioned the motor and squirrel cage, you may be rubbing the inside of the surround. When I installed the Olds electric motor, I could not just replace the motor but needed to create an adapter out of a piece of metal to allow movement for correct placement of the squirrel cage within the surround.
One installed and after validating its operation, I trimmed and painted the full unit and now you can't tell there is a optical difference.
Hope this helps,
Ray(64BJ8P1)
R
RestoreThemAll
Yes Ray, I installed the original squirrel cage. I had to turn down the motor shaft slightly but it fit. It's not hitting anyplace.
I'll observe it running with these things in mind.
Dale
R
RestoreThemAll
I googled how to balance a fan cage. Not much for cars but HVAC had some good stuff. My fan motor is tight so the cage doesn't move easily enough to balance on the bench. I did test it by turning it off and on and watching it just before it stops to see if there is any wobble. It's hard to see but there is some slight movement showing its not 100% true. That's probably causing the vibration. Now I have to decide if I can live with it or take it apart.
Dale
RAC68
Hi Dale,
You might as well start taking the unit appart as you will keep thinking about the imbalance every time you turn the bolwer on and it will agrivate you. However, if you use the blower as often a I do (almost never), then living with the issue will not be as much as a problem.
I am in the same situation with my having something lose banging when I have a low rough idle. Disassembling carburetors, intake and exhaust manifolds to install new engine mount rubber is not something I will consider as long as the banging keeps disapearing at higher RPMs or when running (even at slow speeds on rough roads). In my opinion, the issue is not that improtant or agrivating to equal the effort and risk of creating new issues when taking everything apart.
So, can you live with the vibration the few times you will activate the blower?
Ray(64BJ8P1)
R
RestoreThemAll
Ray, you convinced me. It's coming apart this weekend. It's better to do now than later when the motor bearing wears out prematurely. I'm not exactly getting more physically flexible as time passes either.
Dale
bob hughes
(not exactly getting more physically flexible as time passes either.)
Join the club :excitement:
It comes with old age don't you know. I am contemplating a rear end (trunk floor on my BJ7) re build before I seize up completely.
:cheers:
G Heater Control Valve AH BJ7 - O-Ring Placement[s] Austin Healey 2
5 WTB: BJ7 Squab Austin Healey 13
5 BJ7 Boot Rust-Through Austin Healey 13
B For Sale Too many Healeys - BN2, BN4, BT6, BJ7 For Sale Austin Healey Classifieds 0
Walter74 BJ7 Throttle Linkage "Support Panel" Austin Healey 5
T BJ7 Trim Recession (Convertible Top) Austin Healey 2
ModifiedBJ7 BJ7 Windshield Surround Rubber Seal Austin Healey 2
R New Hood for BJ7 Austin Healey 3
chicken BJ7 Chrome Trim Austin Healey 15
JMACENGINESHOP BJ7 Engine Rebuilding Austin Healey 23
R BJ7 Rear Axle Maintenance Austin Healey 5
B Wanted Grill Top Cowl and Surround - BJ7 Austin Healey Classifieds 1
R Changing BJ7 Differential Ratio Austin Healey 10
X Trouble shooting trafficator - 1963 BJ7 Jaguar 9
T BJ7 Hard to find First Gear when G/Box is hot Austin Healey 3
B BJ7 Rear View Mirror Mounting Hardware Austin Healey 7
chicken BJ7 Door Fit Austin Healey 27
T Wanted BJ7 parts needed Austin Healey Classifieds 0
T Weight of BJ7 Transmission/Overdrive Austin Healey 10
D BJ7 Clutch Austin Healey 6
R BJ7 Back Seat-Rest Austin Healey 1
HealeyRick BJ7/8 Convertible Top Issues Austin Healey 5
HealeyRick BJ7 Side Window Alignment Austin Healey 31
B BJ7 Interior Finishing Details Austin Healey 2
chicken Healey BJ7 door (i think) Austin Healey Classifieds 0
chicken BJ7 Rear Number Plate Mounting Austin Healey 3
chicken BJ7 Door Seal Austin Healey 5
chicken BJ7 Rear Quarter Panels Austin Healey 6
B BJ7 Boot Trim Austin Healey 7
T Early BJ7 Vent Window Seal Austin Healey 2
D BJ7 Underdash Trim Austin Healey 9
G Steering Arm Installation Recommendations - BJ7 Austin Healey 2
D BJ7 Rear rail trim Austin Healey 0
D BJ7 Hood frame mounting plate Austin Healey 7
D Wanted BJ7/8 front grill top cowl Austin Healey Classifieds 4
BLong63AH BJ7 Hard Fuel Lines Austin Healey 20
T Spin-On Oil Filter Removal [BJ7] Austin Healey 12
T Installing Garmin GPS in a BJ7 Austin Healey 19
pbraun How much does a BJ7 or 8 transmission weigh? Austin Healey 3
P BJ7 Upholstery Austin Healey 1
B BJ7 back end rebuild Austin Healey 1
Marvin Gruber BJ7 door panels Austin Healey 4
Marvin Gruber BJ7 Top Installation Austin Healey 1
B Rear shroud connection to the floor pan on a BJ7 Austin Healey 21
P BJ7 HS6 Carb Baseline Setting Austin Healey 10
Marvin Gruber BJ7 tach cable location. Austin Healey 3
T Toyota 6 cylinder eng & trans in a BJ7 Austin Healey 0
BJ8Healeys BJ7/BJ8 Exhaust Systems Austin Healey 24
W For Sale Hardtop for BJ7/BJ8 on BaT : No Reserve Austin Healey Classifieds 2
