RestoreThemAll
I have a positive ground BJ7 with an SU solid state fuel pump. When I drove this car during the 1970s it had a JC Whitney fuel pump. I have no idea of where the single white wire from the fuse box connects.
As you can see in the attached pic circled in red, there are two electrical connections. I'm assuming the connection nearest the outlet pipe is for ground? Then the connection at the back of the pump would be where the white wire from the fuse box connects?
Then circled in yellow is what looks like a vent. Is there a hose or something that connects there? Circled in green seems to be a vent capped off?
Just trying to understand and get it right.
BTW; who mounts a fuel pump practically in a wheel well? :highly_amused:
Dale
Dale
