sultanoswing
Weird.
My right tail lamp (and brake light) is working just fine.
My left tail light is not working (the brake light is). All other lights are working front and back, and turn signals are all going.
The wierd thing is, when I voltage test the socket, there 11.5 volts across the poles, the earth is good - but the bulb won't light. before you ask - it's not the bulb - I've swapped it out with the other side - and it works, and the other bulb (which works in the right) won't go in the left socket.
Suggestions? /ubbthreads/images/graemlins/confused.gif
