longbridgehealey
I don't even know where to start with this. Here's the short version. Last summer our 100-6 starting jerking hard to the right when the brakes were applied. Upon investigation, various leaks were discovered. The front wheel cylinders we're rebuilt, the master was rebuilt, new front brake shoes, and new lines between the front wheel cylinders.
After various redo's and tightenings, all the leaks were corrected and it no longer jerked when the brakes were applied. Now for the problem...
First, heres what we are working with. This car is a true Longbridge built 100-6, built in 1957. After fixing the leaks, we could not get first pump pressure on the brake pedal. It would go to the floor on the first pump, then get good locking pressure on the second pump. After messing around with this issue for weeks, I finally gave up and called my good friend Doug Reid, who many of you know as being a pretty good Austin Healey mechanic. His advice was to keep bleeding the car and the problem would probably be solved. Well, after bleeding it so much that I felt like a vampire, I decided that I just wan't going to fix this issue. So off the car went to Bruce and Inan at Healey Surgeons. It's been two weeks, and Bruce is pulling his hair out. After duplicating what I had done, and replacing the master cylinder, here what else he has done:
replaced all three brake hoses
replaced all six wheel cylinders
replaced all brake shoes
bled the car three different ways
changed the front wheel cylinders to 7/8 from 1 inch at the suggestion of Tom Kovacs at Fourintune
replaced my master with a nos one, didn't do any good so replaced mine
where are we? The brake pedal still goes to the floor on the first pump, then gets good locking pressure on the second pump.
Bruce knows I'm posting this, he said forward him all ideas we get, he's at his wits end over this. Inan said it's the first time in 40 years that they could not figure a problem out.
any ideas?????
Larry
any ideas?????
Larry
Hi Guest!
