Went for a 60 mile drive on the 4th of July. About half way I noticed the smell of oil. The Oil pressure was lower than normal. Normal is low anyway, but that is another project for another day. Popped the hood and noticed oil all over the underside of the hood and just about everywhere else. Dip stick did not register at all. Added almost 3 quarts of oil and drove home, adding another quart on the way. The first project was to clean up the mess as I had no idea where the leak was, as oil was dripping from everywhere. Talk about marking your territory, this Healey was claiming the whole county. After the cleanup I noticed oil coming out of the rear tappet cover. The gasket was very mashed up. Blame the PO. So off to Autosport, our local parts house, for a new gasket. Problem solved. Not yet. Another drive found a significant leak. At first it looked like the hole in the bell housing, but further examination showed oil coming down the side of the bell housing and dripping from the cotter pin in the hole. Now what. Autosport suggested the back of the valve cover, head gasket (new though), pressure relief nut, oil line to the guage, or even the oil pan gasket. Valve cover ok, head gasket shows no leak, nothing from the relief valve nut or oil line to the guage. So I tried tightening the bolts to the oil pan. I probably was able to get a full turn on each nut without applying too much torque. To tired for another drive or test tonight but I hope that is the problem. Other ideas, just in case, anyone? By the way, the replacement gasket for the tappet cover was rubber, not cork, and it seems to provide for a much tighter seal. Thanks.
