CJD
Moving up the ignition...
I've been cleaning what I have and referring to the diagrams for the big three suppliers, but I am still confused on a few points about the ignition coil.
The judge's guide says all the early cars had the "big" coil. What is the difference between the big coil and the later coil? Also, did the early coils use studs and nuts for the low tension connectors...vrs. spade connectors? Finally, how does the "screw nut" high tension lead work?
Thanks!
Thanks!
