My XKE only has about 45K miles. About 2K miles ago I had a small oil leak and replaced the cam cover and gaskets and resealed the cam blocks. I recently and stupidly took the car to Jiffy Lube to change the radiator fluid. After competion, as they pulled the car out of the bay, it overheated and sprayed fluid all over the engine and car. At the time they said it was caused by them putting on the wrong radiator cap. They wiped off the car and hose sprayed the engine compartment. When I went to leave the engine sputter. The manager said it was a wet distributer. I made it less than 3 blocks before she shut down. I called for a flatbed. When he arrived hours later, the car started so he followed me as I drove it home (about 1 mile). It failed to start again other than a raspy sputtering filled with white smoke. It's now in the shop and I'm being told the white smoke indicated the engine needs to be rebuilt and they stated that there was radiator fluid actually mixed in with the oil. As I'm not confident of anyone's diagnosis and since I assume there may be a fight with Jiffy Lube, I need to do some homework. Any thoughts and recommendations would very much be appreciated.
