Tabcon
"Yes, I'll have the biggie brakes and the biggie fries." "Would you like to add a biggie wheel to that order?"
Oh boy, it seems as if everything is available in a larger size now. Nothing is ever big enough for us glutenous Americans with an appetite for everything huge. Speaking of which, I would like to add a set of new 4 pot calipers and larger rotors to the front end of my car. I've checked out several outfits offering "big brake" kits, but they are either too expensive or not really what I want. I've narrowed down the parts I need at Wilwood to do the job, that is all except the proper sized caliper mounts. I want to go with a either an 11.75" or 12" drilled and slotted rotor but I cannot locate any after market caliper adapters to mount the calipers on. Some of the kits I have looked at seem to come with what appears to be aluminum brackets that I assume attach to your stock caliper mounts that must push the calipers further away from the hub.
Has anyone here ever installed a big brake kit or fabricated one on their own? Are the adapters something I could have easily fabricated or are they available anywhere?
I really don't want to use any guesswork when it comes to the brakes so any help would be appreciated, not to mention better for my health.
