BFH method of steering wheel removal
G
Here's the results of the BFH method of steering wheel removal gone sour. Notice if you can how the threads on the end of the shaft are gone. Gone from beating on the nut until they were sheared from the shaft. Repairable? Yes, I can repair it but it takes several hours of my time to do the job. Worst thing is that it didn't have to happen. Please guys, use a puller instead of the BFH unless you are looking for a reason to replace your steering column
tony barnhill
Great Pumpkin - R.I.P
Gerry - did it also damage the collapsible shear pin?
G
Haven't taken it apart yet. Sometimes the slipjoint escapes noticeable damage. This was a column I bought for stock so it will be repaired whenever my stock dwindles. FWIW, I have 6 or 7 columns on hand with similar damage. One of these days I will take a whole day of doing nothing but repairing threads. BTW, I can convert the fine thread 68-69 columns to later coarse threads during a rebuild, too. It's a good way to get rid of that NLA 68-69 nut
tony barnhill
<div class="ubbcode-block"><div class="ubbcode-header">Quote:]I can convert the fine thread 68-69 columns to later coarse threads during a rebuild, too.[/QUOTE]
Good to know...does that mean that if I tell you what steering wheel hub I want to use, you can match its threads?
G
It means I have a method of replacing the threaded section of the upper steering shaft. I cannot(will not) alter the splines because of the possibility of the repair failing. There is no real stress on the threaded part of the shaft-all it does is hold the wheel on the splines and takes none of the rotational stress. So the purpose of my repair is to restore columns to use that have had the threads damaged OR convert a 68-69 column to use the late coarse nut instead of the early NLA fine thread nut. Both of these jobs has to be done in conjunction with a total column rebuild because the column has to be completely torn down for me to do the machine work needed
T Pivot bolt stuck - BFH time? Triumph 8
71TR6 TR2/3/3A Slight tweak to Martx-5's dogleg covering method Triumph 9
M BJ7 back panel fixing method Austin Healey 5
T TR2/3/3A What is best tool, and best method, for widening gaps on TR3A grille? Triumph 21
K TR2/3/3A Clutch bleed using"gravity bleed" method? Triumph 4
glemon New Painting Method Restoration & Tools 2
doc50 Best Method to weld sheet metal repair panels in... Triumph 10
K Saving a clutch disc.....old school method? Triumph 11
H removing steering wheel...method? Austin Healey 9
KLUTZ Easiest method for connecting Emerg. brake cable MG 5
J Balancing Wire Wheels - Old Method? Triumph 3
bigjones Timing by the vacuum method Spridgets 4
K Method of breaking stuck clutch disc free? Triumph 10
MGBGT_noob The great welding method controversy MG 12
chicken Best method for getting the two tone line right on Austin Healey 4
A Steering box - Pitman arm removal method work? Austin Healey 10
jjbunn PDWA Seal Bolt Removal Method Triumph 12
T Third gear installation best method Spridgets 10
Popeye Method to remove Bondo Triumph 2
B FAST & EASY CAR DRY METHOD Restoration & Tools 2
P "Head Method" for trunk use Sunbeam (Rootes) 3
tr6nitjulius For Sale SOLD 3/7/24: 4$ale Hi-ratio quick steering rack Triumph Classifieds 0
T TR6 Steering Wheel Lock Triumph 2
D Removing the steering wheel hub Spridgets 12
J MGB 1970 MGB Steering Lubrication MG 1
C Steering Arm Castle Nut Torque Austin Healey 5
PAUL161 T-Series TF Steering Rack MG 0
G Steering Disconnected Austin Healey 2
R TR2/3/3A Jammed Steering Box Triumph 10
R TR2/3/3A Steering Box Gaskets Triumph 4
K 1968 Midget Steering wheel Spridgets 1
olarson TR2/3/3A Steering Column Bracket Triumph 2
Guido36 Electric Power Steering Austin Healey 2
Rut MGB 62-67 upper MGB steering shaft MG 3
Editor_Reid Wrapped Steering Wheel Austin Healey 9
E TR6 Strange Steering Rack Cap Triumph 3
B TR4/4A Steering Wheel Hub Issues Triumph 0
K TR2/3/3A Who sells steering wheel control head "Allen head'' grub screws? Triumph 5
S TR6 Steering question you will not hear every day Triumph 1
T "Flashpower" Steering Wheels Austin Healey 3
EWD For Sale ā€˜74 TR6 original steering wheel Triumph Classifieds 0
S SOLD!! Mike Lempert 15" slotted Derrington Steering Wheel Austin Healey Classifieds 1
M Midget steering column Spridgets 3
kodpkd Leather Steering Wheel Cover Austin Healey 3
JAV For Sale non adjustable steering box Austin Healey Classifieds 3
S Steering Wheel Brand Austin Healey 5
71TR6 TR6 Replaced steering rack in my TR6- very twitchy now Triumph 15
B TR4/4A What is this Steering Wheel Center? Triumph 6
M MGA RHD twin cam steering pinion MG 0
W BN1 Steering Box Removal Austin Healey 11
