Nunyas
To sum it up, I just have no idea what the deal is. The B just has 0 power if I can get it to run long enough to try and move it, as of late this morning. I ended up 2.5 hours late to work because I couldn't figure out why the car is behaving like it is. So, I'm here looking for suggestions, tips, and hints into things I should check.
First the symptoms:
-the B Starts
-the B idles after starting (smoothly most of the time)
-the B starts to rev up when I give it gas, but then stalls
-If it doesn't stall after reving it'll idle extremely rough
-If I apply choke it idles higher and it'll rev higher, but lacks power
What I think I know:
-I think the HS6 is still good. It's freshly rebuilt. It worked all last week without issue.
-I think the SU Fuel Pump is still good. Every time I think I have a supply issue, I check the fuel line for pressure at the carb and it has always been good.
-I checked today to make sure fuel is getting into the bowl. With the pump on, I opened the lid a little and lifted it enough to let the fuel flow and eventually over fill the bowl.
-It's on a fresh full tank of gas. I drive the car daily, and fill it with 'hi octane' fuel. So, I'm 99% sure the gas isn't "bad".
-The ignition should be good. It has a Crane XR700 that's ~never~ needed adjustments since I got the car. The dist cap is new, and looks good. The plugs are new and look good (aside from having a lean running color on them). The plug leads are new and good.
-No matter how many flats "Rich" I go on the HS6, the car behaves the same.
-The car is getting both FUEL AND Spark: otherwise it would not even idle.
Things I've checked so far:
-I've traced the wires and checked and cleaned ignition wires in the wiring system, from the fuse block to the ballast resistor, to the coil, and to the XR700 leads.
-I've check the dist, to make sure it's all clean inside, and to make sure no moisture is getting inside.
-I've checked to make sure the heater valve isn't leaking on the dist.
-I've checked fuel pressure at the bowl.
-I've checked to make sure fuel is going INTO the bowl.
I initially thought ignition problem, because this morning it initially would not go past 1k RPM without dieing. Later, I found it will go up to at least 3K without dieing, but only if it's on 'choke idle'; using the gas pedal results in stalling, or no power.
Now, I'm thinking it may be fuel supply issue. I've checked everything from the fuel tank to the float bowl. I removed the fuel filter this past weekend, and it's eating away at me, making me think that doing so was a major faux paux on my part. The only thing in the fuel supply system I have NOT checked is for blockage between the bowl and the bridge (i.e. the jet and its plumbing).
Things that lead me to believe it's blockage in the jets:
-On FULL choke it used to idle a hair under 1K RPM with extremely rich characteristics (i.e. cyclic rough idle).
-On FULL choke NOW it idles up to 2.5K - 3K RPM smoothly.
-When I step on the gas it starts to rev up, but stalls if I give it too much pedal.
It could be something else though... It may only be coincidence, but bumps seemed to help the symptoms come and go.
I guess the carb piston could be getting stuck or something. I haven't looked into it since the problems started. So, I don't know if that's an issue, yet.
erm...
I think I've started down one of those paths where I'm typing what I'm thinking and I'm just rambling on...
ANYWAYS, thoughts or opinions anyone? Any and all feed back will be appreciated.
Thanks for reading
First the symptoms:
-the B Starts
erm...
Thanks for reading
Hi Guest!
