Wedge Best electronic ignition for my TR8
DNK
Typical answer would be Woody. Know he sells the Mallory but not sure if that works for the FI.
Asked that question about my OBD1 and haven't heard.
tdskip
Hey Larry!
I installed a Mallory from Woody and it's been great, although with the oil and new clyinder heads and floor repairs I haven't driven her much.
philman
I'm using a Mallory unilite distributor with a MSD6 ignition box.
PATR8
I have Mallory Distributor and MSD6 Box too. I like it a lot.
philman
I made a component plate and mounted my msd box under the glove box with the fuel pump relay and ran an auxillary harness through the right wing. With an optical distributor you don't worry so much about stray magnetic fields. It seems to work well. The regular molex connectors are rated at only about 10 amps so I purchased some johnson pole connectors rated at 30 amps from a ham radio supply store. Some people recommend running the MSD box power on dedicated wires directly from the battery. I still have to sort out the tachometer, with an msd box you will need to either purchase a tach adapter or get wedge shop to modify your existing tach. Woody can explain why, I just haven't got around to it yet, other bugs have a higher priority.
T
Tinster
Don, the Mallory dizzy?
Is it a stright replacement for the Lucas?
Or must other things be modified.
d
DNK
I have a Mallory in my 6. It does not come with the drive cog on it. I bought a new one and installed it on the Mallory dizzy. You have to drill a hole for the cog pin in the dizzy.
That said, it won't work for our tachs. I had the Gauge Guys redo a tach I got off eBay to run by the electric dizzy. One day I'll see it work.
R
RonMacPherson
Cuz,
From your description of problems the problem is not IN the distributor the problem is supply to the distributor.
That's why I want you to monitor supply voltage to the distributor.. Something is burning out your condensors... It is NOT normal for a condensor to have such a short life....
The condensor, actually a capacitor, is an electric sponge, sized for the voltage input to the distributor. Once you find out the condensor specs you can go to Mallory, Accel or Blue Streak, three known quality ignition manufacturers and purchase a condensor that will work in your car... Days of old(I'm talking when we were both riding tricycles here) Condensors were not usually replaced when the car was "tuned up"..As they were so reliable. Then the parts people started pushing them, so the tuneup kits came with condensor included. Once in a while you will get a faulty condensor, but it is a rarity...
I still think you are getting a voltage spike to your coil/distributor..... Your symptoms are consistent with that.
There are also other ways to "attack" your problem. You can convert the ignition to either Ford or Gm electronic ignition systems. Search the web as they have been put in cyber space long time ago. The beneficial thing about those conversions is not that costly and less susceptible to voltage fluctuations....
B What is best electronic ignition setup MG 19
SherpaPilot Best Electronic Ignition? Triumph 9
mctriumph TR2/3/3A the best kinda folks Triumph 2
K TR2/3/3A What is the best way to prevent the crank from turning ........ Triumph 27
tr6nitjulius For Sale "SOLD" Winter projects: Upgrades 4Sale or Reasonable Best Offer Triumph Classifieds 0
AngliaGT MGB-GT The Best Laid Plans....... MG 3
69MGC T-Series Best Technique to Clean a Canvas Top MG 3
Michael Oritt Best Seat Trim Adhesive Austin Healey 8
J Best Aluminum Fenders? Austin Healey 3
1 TR2/3/3A Best Rustproofing for inside of body. Triumph 7
G Best fuel option for a 72 Midget Spridgets 5
Celtic 77 MGB Looking for best info regarding throttle cable replacement. MG 16
JPSmit some days your best tool is a credit card Spridgets 2
dripdripdrip TR2/3/3A Best place for tonneau & hood stick covers? Triumph 2
D The best place to get shocks rebuilt. Spridgets 8
Joel Lester TR2/3/3A Advice for which head gasket material is best Triumph 8
BoyRacer Best-Sounding Muffler - Stainless Steel or Mild Steel? Austin Healey 9
W Best source for Bugeye front shocks Spridgets 3
J For Sale For Sale - 2x TR6 seats in red vinyl - Best Offer! Triumph Classifieds 1
Bob Claffie Best cruise in of the year Spotted 8
longbridgehealey Best way in Austin Healey 2
B TR4/4A What really is the best clutch/bearing combo Triumph 4
I Best glue for rubber door panels? Spridgets 3
N Best cam choice??? Spridgets 5
R TR2/3/3A Best day ever [so far] Triumph 1
C How best to restore red script on valve cover? Austin Healey 7
F Best $25 I've ever spent on my Healey - 2019 Austin Healey Concours Guidelines Austin Healey 0
FlyingCat Spitfire Which carburetor is the best? Triumph 9
T TR2/3/3A Where is best spot to check temp with infrared thermometer? Triumph 17
D Best little tube bender Restoration & Tools 8
N Best lube for a Datsun gearbox?? Spridgets 6
Kleykamp For Sale 1978 MG Midget Best Offer Spridgets Classified 0
DornTRoriginal TR2/3/3A Electrical Wiring Best Practices Triumph 13
I General TR Best car cover Triumph 8
M Best Interiors Austin Healey 20
Jer Confirming the best choice for clutch / release bearing for my 67 Midget Spridgets 2
N Best carpet glue???? Spridgets 5
S Best Ethylene Glycol/Water Ratio to avoid overheating? Why? Informal Survey. Austin Healey 27
B best diff British Motor Corp 5
Boink Pre-War MG-TB wins best in class at Forest Grove Concours MG 7
T TR2/3/3A What is best way to flush engine after antifreeze got in oil?? Triumph 2
GTP1960 Not the "best car ever made" by a long shot Other Cars 14
glemon Mercedes 450SL Best Car Ever Made? Other Cars 7
cpbol Best alternative option to sleeved thermostat? Austin Healey 9
MisterB Spitfire Best year for a Spitfire? Triumph 12
D TR4/4A Best SU overhaul service to use? Triumph 10
K TR2/3/3A What is best way to remove old nylon/rubber bush 525-020 from steering box shaft? Triumph 5
Gerald_Gordon TR4/4A Best carpet for TR4 Triumph 2
C Best Replacement BN1 Leaf Springs Austin Healey 5
Jim_Gruber Headlight Trim Rings on my BE - Removal - Best Methods Spridgets 5
