I got some bad news today from my bodyshop. It appears that the frame on my 4 is bent beyound reasonable repair.
At some point the car took a preety good hit to the right rear wheel area. This damaged the frame on the right side but also bowed out the rail on the left side too. To make matters worse they added a new right rear wing to the car without repairing the frame damage.
If you stand behind the car and sight down the right side from front to rear it is no longer a straight line but a very noticble curve to the inside. Maybe as much as 1-1.5 inches. The right door has a gap of about 1/2" between the B post and door. You can actually lift the right rear end of the body up about 4" and close this gap up.
I sent the car in for new floorpans and inner/outer sills and they found all this after it got there.
I trust this body man but I also had a very knowledgeable foreign car friend of mine come to take a look at it. They both say Its just not worth the cost it would take and then it may not be right. The cars pretty rought to begin with.
Your thoughts are appreciated. Scott
Hi Guest!
