TR2/3/3A Bellows thermostat for tr3
sp53
Bellows thermostat for tr3 and Metropolitan Nash Thermostat are interchangeable. There is a guy selling some NOS ones for the metro for 22.00 out of Kentucky on eBay. I think were made right there also probably back in the 60ites. I am not sure if he knows they are interchangeable with the English stuff. I bought one and they look ok, so I thought I would tell the forum. If I remember correct, the tr3 and metro rag top are the same also.
TRopic6
SP,
I took a look at the auction, and while it is a bellows thermostsat, there is no ring to seal off the bypass. What operational difference that makes is debatable, but it may matter to some.
Jeff
TR3driver
Great Pumpkin - R.I.P
Indeed the sleeve to block the bypass would be the only reason for using a bellows thermostat at all, IMO. A modern "wax pellet" type works far better at controlling engine temperature.
mrv8q
Hmmm, I have a Lucas LF2 bellows-style thermostat, and besides the TR 2, 3, 3A and 4, others are specified: Aston Martin DB5, Jag 120 and 140, various English Fords, Rileys, Wolseleys and a Rover.
No Metropolitan mentioned. Were Nash Metros only sold in the States?
TR3driver
mrv8q
Well done, Randall! Should have read a little further:
Austin A35, A40, A50, A55 Mk I, A90, A95, A105 and.....Metropolitan!
Although, in my defense, I was looking for Nash.
Great catch!
S
sp53
Ya I am not totally sold on them either, I just like the box and complexity of the thermostat. I did drop it in hot water, and when it opens it kinda makes a flat area for the shutting off of the hole, but again I have the real deal blanking one in my driver.
Geo Hahn
...Austin A35, A40, A50, A55 Mk I, A90, A95, A105 and.....Metropolitan! Although, in my defense, I was looking for Nash...
Just an FYI... there was also a Hudson Metropolitan. Mostly badging and some extra chrome. Fairly rare, I only know of this because there is one 'parked' locally that I have seen.
TR3driver
At that point, Nash and Hudson had merged to form AMC, so it was just a matter of putting a Hudson badge (and a few other trim items) on the car, and selling through Hudson dealers. Later on, AMC dropped the Hudson and Nash names entirely, calling the car simply "Metropolitan" and selling them through Rambler dealers.
Andrew Mace
EDIT: I found them on eBay! [Would you happen to have a seller ID or auction number (link) to these?] The bellows-type thermostat are also useful / mandatory on some Heralds due to location of the temp. gauge sender on the earlier Heralds.
TR3driver
Can you expand a bit on that, Andy? I don't understand. The bellows thermostats are larger in every direction than a wax capsule type, so it can't be that the sender interferes mechanically with the thermostat. Can it?
tr6web TR6 TR6 Gaiters [bellows] Triumph 11
DerekJ Bellows Fuel Pump question Austin Healey 2
K TR2/3/3A Further to "plugging the thermostat bypass hose"/ Triumph 25
K TR2/3/3A Thermostat for hot summer driving? Triumph 1
S TR2/3/3A 187 NOS sleeved type thermostat Triumph 16
Twit TR4/4A shining up thermostat housing Triumph 9
Lin Thermostat and blanking Sleeve question again Austin Healey 7
R TR2/3/3A Thermostat and bypass hose Triumph 15
T TR2/3/3A Question on TR3 thermostat from TRF Triumph 6
M Tr6 oil cooler - do need a thermostat n Texas? Triumph 3
AUSMHLY BJ8 Thermostat Austin Healey 4
Healey Nut Thermostat blanking sleeve Austin Healey 13
RAC68 Radiator Core Replacement and Sleeve Thermostat Alternatives Austin Healey 20
D BT7 Thermostat Austin Healey 1
D BT7 thermostat gasket Austin Healey 7
cpbol Best alternative option to sleeved thermostat? Austin Healey 9
C Corrosion of the thermostat cover Austin Healey 8
R TR2/3/3A Correct Thermostat? Triumph 7
O TR2/3/3A Thermostat housing Triumph 3
AN6-TX 948 Thermostat Housing Spridgets 11
steveg Robertshaw sleeved thermostat Austin Healey 3
mgedit TR2/3/3A Quick Question on Thermostat Triumph 14
S TR2/3/3A used thermostat Triumph 5
B TR6 Which thermostat TR6? Triumph 3
P Overheating after shut down & recommendation on thermostat Austin Healey 3
R correct thermostat Austin Healey 3
steveg Thermostat questions Austin Healey 44
R Thermostat revist Austin Healey 11
T TR2/3/3A How do I remove temp gauge capillary end from thermostat housing on TR3A? Triumph 8
R looking for Moss 363-370, 1500 thermostat housing Spridgets 13
KVH Thermostat Housing Gasket--Must the Sealant Dry? Triumph 3
J TR4/4A TR4a Thermostat Triumph 2
GBT remove thermostat MG 11
K TR2/3/3A Who is running a Sleeved Thermostat in their TR3? Triumph 16
Anthony_S Thermostat Triumph 4
M 99 XJ8 Thermostat Housing Failure Jaguar 0
Skip_Shervington TR2/3/3A TR3A Thermostat Housing Leak Triumph 6
Morris Thermostat vs. Pinging Spridgets 14
R TR4/4A Tr4a, what engine thermostat for San Diego Triumph 9
M Headremoval and thermostat.. Austin Healey 3
R Need more heat - which thermostat MG 15
RJS Thermostat Stuck Open? Triumph 11
Darrell_Walker Wedge TR8 hoses, thermostat, etc Triumph 2
hondo402000 getting rid of my oil cooler, hoses, thermostat Triumph 2
rlich8 TR4/4A TR4A Thermostat Bypass Triumph 5
BugeyeNJ58 Geo Metro Radiator - need thermostat housing Spridgets 10
Westfield_XI What if the thermostat was in upside down? Spridgets 9
D Thermostat Austin Healey 37
T TR2/3/3A TR3 thermostat rating Triumph 4
M T-Series Thermostat Switch Question MG 11
