TR3driver said:Oh yeah, check the bore where the seal goes as well. If you or a previous mechanic managed to gouge it while prying out the seal, you need to repair the damage or it will leak.
DrEntropy said:Now I fear we're scarin' Elliot, Randall.
All is contingent on both good, non-damaged I.D. for the seal O.D. and a proper size I.D. seal with a non-scored surface on the shaft O.D... Some Hylomar on the seal O.D. can sorta fix that issue but if the seal isn't the right I.D. or the surface of the shaft is undercut, a sleeve is a viable "good fix".
The visual inspection will tell the tale.
