I have a 1500 engine in it. I have already cleaned the transmission up, painted bell housing, etc Took a look inside from the top, all the gears seem ok.
My plan is to replace the gaskets, rear seal, copper washer.
https://www.mossmotors.com/Shop/ViewProducts.aspx?PlateIndexID=113329
I am also aware I may need to swap the flywheel. I am replacing the clutch and throwout bearing while I have it apart as well, pilot bushing tool
I also have a drive shaft with a cv joint. can't get it apart, was going to perhaps buy a new one from Spitbits.
which gaskets require sealer? what else should I do?
