Before and after top with 303 Aerospace protector
RickB
There was a break in the rain this afternoon, the sun came out!
So I washed the vinyl top and then rinsed and dried it and then sprayed and wiped off the 303.
I think it made a huge difference, can't wait to see how it performs in the rain!
Before and after pictures.
I did nothing to the pictures at all besides made them smaller so they fit better here.
Notice I failed to wipe the stuff off the body at the bottom of the second picture, wiped it off after I saw the pic...
RickB, that really turned out good! I've gotten the 303 on bright trim and painted surfaces and it's never caused a problem. Your top looks new again.
Rut
Looks great! but FWIW I have no desire whatsoever to see how my top performs in the rain. I don't even have a desire to see how well it folds up.
303?
Aerospace?
Performs in the rain?
Expecting meteor showers? :jester:
Never heard of the stuff, what's it supposed to do.
OK so my almost new top that has been folded up under the tonneau cover for the past 3 years has oxidation on the windows already. Got a solution for that anyone? Just about zero direct sunlight as car sits in garage rest of the time.
Check this out. I've used it and it really works
Autogeek is having free shipping for the next 47 minutes.
https://www.autogeek.net/meplclplclpo.html
PlastX by Meguires works good too for the clear windows.
It's something I have used and recommend, I am sure the Mothers product is at least as good.
303 Aerospace:
https://www.autogeek.net/32oz.html
<div class="ubbcode-block"><div class="ubbcode-header">Quote:]303 is the leader in UV screening technology and 303 Aerospace Protectant really is like "SPF 40 Sunscreen ... For Your Stuff." Regular use of 303 Aerospace Protectant can reduce UV caused slow-fade by up to 100%. No other protectant beautifies as intensely, protects as powerfully or lasts as long.
The World's Most 'Manufacturer-Recommended' product: Because of its enduring cosmetic properties, resistance to dust, soiling, and staining, water repellency and unparalleled protective abilities, manufacturers worldwide recommend 303 Aerospace Protectant for countless uses:
Use on Rubber: Latex, Neoprene, EPDM Seals, weather-stripping, Wet/dry suits, rubber roofs, Vinyl, Hypalon, Urethane Vinyl awnings, clear vinyl, convertible tops, tonneaus, car bras, spa covers, pool covers, inflatable boats and so much more ![/QUOTE]
