Been thinking - about time.
jlaird
If Miss Agatha is not driven weekly the fuel that should be in her float chambers seems to evaporate. Really makes her a pain to start ie it takes a few cranks.
The only thing I can think is that the gasket around the top of the cap part needs replaceing along with the overflow line gaskets.
See no leaks.
Gona go look and see if I have some. Noop gona have to make a purchase.
Do you guys agree or do you have a better idea? I don't think I changed these when I rebuilt the carbs a few years back.
On target Jack!!
They will deteriorate over time.
Steve
Durn, it was the Float Chanber lid washer.
If I go out and rub my finger along it I get a bit of fuel, just on the washer, not a real leak.
See no leaks.
First, congrats on your latest award. :cheers:
Jack, as I recall, you have HS1's, yes?
I think these are prone to leaks both from the underside of the jets, as well as from the bottom of the float bowls. I think that is a more likely scenario.
I'm wondering with your fuel filter being below the carbs if you are; getting a siphon effect or perhaps a leak down the line? Place some white paper on the floor underneath and see if you have any telltale spots.
For those of you who haven't seen Miss A before, here's a few pix of Miss Agatha in the hotel lobby at LoTo.
Wow, what a nice looking BE Gerard. LOL
Will go out and check bottom corks and such with my trusty finger. Back, no bottom leaks or sepage that I can find other than that darn top ring.
I think I found the problem, as usual with you guys listening as I go through it.
Thanks
