mightymidget
I had issues trying to install glass into rubber, I finally gave up and welded studs to light housing so I could bolt unit as a unit from inside trunk.
Is there an easy way to install glass once light is screw tight to body.I tried but could not manage rubber.
With out light housing attached to car I managed to install glass and ring OK. This is why I installed light units with glass installed
This are the lower rear lights on a bugeye.
