billspohn
Steve_S said:Let the "bashing of a beautiful car" begin. /bcforum/images/%%GRAEMLIN_URL%%/devilgrin.gif
"beautiful period correct nut and bolt restoration in both cosmetics and mechanics"
- Wrong map lamp knob
- Radiator not restored
- Dashpot covers probably hiding yucky stuff
- Damper nuts incorrect
- Valve cover nuts painted
- Manufacturer's plate installed backwards
- Didn't straighten the r/h fender mirror before taking photo!
- Top frame painted white
- Underside of car filthy, ground up restored?!?
- Rusty exhaust manifold
- Fluid spraying on lower engine bay
- Driver's door not aligned (hitting pillar)
Still a beautiful car, but the price is already too high.
Good catches, all.
To which I would add:
- a radio blanking plate that looks a slightly different colour than the dash,
- wrong turn signal light and bezel
- missing inner door panel stiffeners
- badly fitting outer front bumpers (the gap between bumper and body often shows with originals though)
- missing central arm rest cushion
- wrong dashpots with cheesy non-original dampers
- don't know that the fan should be yellow that early (but too lazy to look it up)
- wrong fuel flex from hard line to carbs - but the thick size as seen between the carbs seems to be unavailable now
- wrong spare tire cover
- wrong side curtains (should be covered, not alloy)
Don't know if this car should have single window top as no number given.
But after all that quibbling, still a very decent driver, if not quite the concours example they lead you to expect.
Hi Guest!
