The frame member that the steering rack bolts to has been replaced. Sure that it is not in "exactly" the same spot as original (many years ago it was hit on the left front and the repair job on the frame member left it twisted and I had it replaced by a handy welder friend of mine).
The manual outlines an alignment procedure that calls for shims to be likely under the mounting bracket at the pinion end (although I am not sure if it makes a difference if RHD or LHD?).
If I am reading the procedure correctly the point of the exercise is to make sure the pinion stem and steering column are in correct alignment.
As long as that is achieved does it really matter where or which bracket is shimmed? To get proper alignment I have to shim the bracket on the opposite end from the pinion.
Also, which end of the steering tube is "up", the cpen end or the slightly inward rounded end?
