Guy's unfortunately my latches are currently off of Bugsy right now. Doing paint and bondo work, on the bonnet. Give me a couple of days and I can provide pics. I found this image, might help show better how this hinge attaches to the bumper mounts. IT is necessary to grind approx 1/2" off of the back bumper mount bracket bolt so it is parallel to the front mounting bolt. If you ever decide to go back to standard hood setup, bumper could be reattached using a stack of washers back there to obtain proper clearance. On a SWA or RWA Spridget, adding the BE Bonnet does require cutting and grinding off a 1/2" lip on the fender arch that sticks out. After grinding off and finishing, if you did not know it was there originally you would not miss it.
