Jim_Gruber
So far have made some progress with Bugsy II's bonnet with cleaning up the Fender Beading. Old fender beads had been cut off and what was left was really rusty in there and really nasty. Tried cleanup on one side with very narrow groove between hood and fenders. Thin cutoff wheel on a Dremel Tool was the only thing I could get to fit in there. Very slow going over several nights. Trick is to cut the middle of the T section out without cutting the fender or hood. Very, very slow work and it will need some more work to ensure a straight groove exists where a new fender bead with a much shorter/almost cut off T Center section can be glued in.
Driver side was another story. Much wider gap existed and I was able to use very thin cutoff blade on my angle grinder and inside of 45-60 minutes had the complete channel dug out, straight, and shiny. More practice at technique improved speed at the end. Angle grinder actually was easier to use than the Dremel and was steadier and made a much cleaner cut. If you do this,start with wider section of the gap. Dont start with narrow sections first.
Area on lower valence for fender bead will need a lot of work as there are some significant welds every 3 ". Again the front of this bonnet had an early '58 bonnet grafted on and those are some of the welds holding the two pieces together. I may be able to use the angle grinder again to go down about 1/4" so a trimmed down fender bead can be glued on. I'll post some pics later.
Before I head out of town on vacation tonight for 10 days, any thoughts on treating remaining rust in the channel of the fender bead. Rust converter, dump some muriatic acid down there and rinse thoroughly, acetone, Trick is to get something in there to keep the rust I can't reach in an inert state but at the same time not fill up the groove. Need room to glue the new fender bead in place. Thoughts gentlemen?
