John Moore
Trevor Jessie said:OK, I gave it more thought (head scratching). Get a piece of 3/4" plywood and cut a rectangle in it the size of the bump (where it meets the firewall). Then get a 1/4 inch bit of square stock and cut it the size of the rectangle on top of the bump. (round the edges). place some 20 gauge steel on the wood form and sandwich it with another bit of wood identical in size. Screw them together. Carefully place the metal stock in the center and start hammering. A lot of prep, but I think you could make a decent shape. The down side... those bumps are two different sizes.
Thanks Trevor. I'll make it work.
Hi Guest!
